WHAT DO THESE HALF SHAFTS FIT ????
Pauly10
Post by Pauly10 »
Hi fellow members, I wondered if any of you gentlemen or ladies would recognise the half shafts shown in the attached pictures, having sold my ruby I have now only my clifton tourer but was given these half shafts about 12 years ago for my austin ruby and as you can see they are not austin 7. So now having a massive clear up and if I knew the vehicle they fitted then somebody could have them for their vehicle.
They measure 500mm long from spline end to inside flange and 570mm overall including grease nipple, the flange is 120mm in diameter and appears to have a 3 stud wheel/hub fitting, there are 6 splines on diff end. ( Sorry I know the measurements should be imperial but alas we are in a different era)
Many thanks
