When I came to install the new felts onto the axle, they were considerably smaller than the axle and wouldn't slip on dispite being soaked in heavy oil.
So I went to my 3/4 inch socket set and forced larger and larger sockets into the felt centre, to open up the felt until it slipped on the axle.
See pics or attachments.....
A12/4 rear hub felt rings AO66.
- IMG_2367.JPG (628.1 KiB) Viewed 5982 times
Re: A12/4 rear hub felt rings AO66.
I am about to fit the felt seals to the rear hubs, but they seem too thick - I can get around the small hole size with the fitting sleeve I have made. The question is this correct & how tight should I tighten the castle ring? I’m sure it will not tighten to the point that the housing and it’s ribbed lid will touch.
Any advise please?
I’m so close to having a rolling chassis now.
Any advise please?
- Felt Seal
- 6ED5BF9D-93EF-4194-84E6-62B77FA97813.jpeg (2.81 MiB) Viewed 5710 times
I think I just came back to it day after day and tightened it up a bit more as the felt relaxed/compressed.
But I am sure there is someone out there who can tell us the right way.
First hub going back together - the castle threaded ring still has a long way to go to be where it was when I stripped it down, but it had not been touched for 50 years then.
Can any one say how far I need to go please?
- 09A505EF-1125-46F3-A50D-710AD89F8889.jpeg (3.26 MiB) Viewed 5676 times
- 285B464D-F411-4B66-9035-393C7450B63B.jpeg (3.22 MiB) Viewed 5676 times
I fitted new sealed bearings on the front axle recently, so no more greasing there for me. Incredible low price from Bearingboys.co.uk. Oddly, the larger one is metric.
