A12 steering wobble
Posted: Wed Jun 10, 2026 12:57 pm
My clifton has a bad steering wobble over 30mph. Ive found the steering arm rotates in the stub axle by an alarming amount.
I could do with new arm as the pitted corrosion on the shaft is bad and they woodruff keyway is a bit worn.
Has anyone any experience in having these metal sprayed ? Or any other suggested repair?
