Drag Link Play
Posted: Mon Jun 23, 2025 7:17 pm
by JonathanDB
Just joined the forum. I have vertical movement in the n/s drag link end - no horizontal play (1925 12/4 Clifton). Can this be adjusted out or is a new drag link end required. It is probably the original component from when it left Longbridge 100 years ago.
Re: Drag Link Play
Posted: Wed Jun 25, 2025 12:54 pm
Hello Jonathan
If it's N/S did you mean track rod rather than drag link? So far as I'm aware horizontal play can be adjusted with shims. Vertical play would suggest excessive wear. Whilst it may be possible to cure the problem by lapping in with grinding paste I would recommend changing the ball and cups. You need to talk to Steve Newton, the VAR spares man.
Best regards
Martin B
Re: Drag Link Play
Posted: Wed Jun 25, 2025 8:26 pm
by JonathanDB
Thanks Martin. Yes it is the track rod end on the n/s. Thanks for your help. I will get in touch with Steve Newton.
