12/4 carb
Posted: Mon Feb 27, 2023 6:09 pm
by Dave J
Having replaced both jets, the engine is still running too lean and requires choke for engine pull more cleanly. Otherwise, under load ,engine spits and coughs until throttle is closed.
Cant see any blockage as far as I can see.
Float level is at max i.e. just before it floods.
Any suggestions will be welcome.
Cheers,
Dave Jessop
Re: 12/4 carb
Posted: Wed Mar 01, 2023 11:48 am
Hello Dave
With new correct sized jets fitted and still misbehaving I would suspect an air leak.
A leak within the carb would be unlikely unless the butterfly spindle and bushes are badly worn.
Is the carb to manifold gasket OK?
Manifold to Autovac vacuum pipe?
Autovac air valves?
Martin 435
Re: 12/4 carb
Posted: Tue Mar 19, 2024 8:03 pm
by Vintageman62
Has anyone the details of the member who advertised reconditioning of Zenith carbs in the newsletter?
Re: 12/4 carb
Posted: Sun Apr 14, 2024 6:22 pm
by rtalbott
i used
Classic Fuel System
6 Fieldhurst court
Bradford
01274 684143
did my zenith 30h refurbed great job and quick turn round
