12/4 carb
Dave J
12/4 carb
Post by Dave J »
Having replaced both jets, the engine is still running too lean and requires choke for engine pull more cleanly. Otherwise, under load ,engine spits and coughs until throttle is closed.
Cant see any blockage as far as I can see.
Float level is at max i.e. just before it floods.
Any suggestions will be welcome.
Cheers,
Dave Jessop
Martin27
Re: 12/4 carb
Post by Martin27 »
Hello Dave
With new correct sized jets fitted and still misbehaving I would suspect an air leak.
A leak within the carb would be unlikely unless the butterfly spindle and bushes are badly worn.
Is the carb to manifold gasket OK?
Manifold to Autovac vacuum pipe?
Autovac air valves?
Martin 435
Vintageman62
Re: 12/4 carb
Post by Vintageman62 »
Has anyone the details of the member who advertised reconditioning of Zenith carbs in the newsletter?
rtalbott
Re: 12/4 carb
Post by rtalbott »
i used
Classic Fuel System
6 Fieldhurst court
Bradford
01274 684143
did my zenith 30h refurbed great job and quick turn round
