12/4 petrol gauge
Posted: Thu Jun 03, 2021 12:30 pm
by MickA
I have a 1928/29 Austin 12/4 and the petrol gauge is not working, the tank is under the seat and I can't get a stick or rod in to see the level, any body know of a fix, thanks
Re: 12/4 petrol gauge
Posted: Fri Jun 04, 2021 5:38 pm
by kerbut
Mine has a bit of stiff fencing wire bent into a semi circle with notches in the wire to indicate how many gallons are in the tank
Posted: Tue Dec 28, 2021 7:31 pm
by DHutch
Presumably you have the side filler pipe, rather than the large dia direct filler below the seat as our '24 Clifton has.
I believe the gauges work using a cork float, which overtime fails to float.
