DYNAMO CHARGING
Posted: Sat Jun 08, 2019 5:44 pm
by Ray Amos
I have a 1933 Austin 16.Recently the dynamo has started to charge when the ignition/light switch is in the off position.It has 4 positions ...OFF D S H .Has anybody had this before? On top of the dynamo there is a bakelite unit with a brass top,the wire coil inside gets very hot.
Any ideas would be useful.
Ray
Re: DYNAMO CHARGING
Posted: Sun Sep 01, 2019 5:35 pm
by Humphrey47
I can only imagine that the contacts in the regulator box have stuck together. If left unattended it could cause a fire unless there is a fuse in the circuit. A good auto electrician should be consulted.
Re: DYNAMO CHARGING
Posted: Fri Apr 17, 2020 3:36 pm
by Ray Amos
Hi thank you for your reply you must think it was so rude me not getting back to you.
i have only just seen your reply.
Re: DYNAMO CHARGING
Posted: Wed Jan 13, 2021 1:14 pm
by DHutch
Have you managed to correct the issue?
If you ensure the 'notify me when a reply is posted' you should get a notification (and email iff setup) of when a reply is posted.
Daniel
