Hi - I am a new member - just acquired a 1927/8 open road tourer . I am trying to locate the engine number - could someone point me in the right direction please ?
The chassis number is stamped on a plate under the bonnet - is that also stamped on the chassis itself ?
Thank you !
Austin Light Six 16/6 - location of engine number ?
Re: Austin Light Six 16/6 - location of engine number ?
Found the engine number under the grime !
It is located at the front of the block just below the cylinder head . It faces upwards on a flat surface behind the fan .
