Spark Plugs
Pickles
Spark Plugs
Post by Pickles »
Can anyone give me advice on what type/ part number of spark plug to use in my 1927 12/4 Heavy?
Shortstroke
Re: Spark Plugs
Post by Shortstroke »
NGK AB6 or champion D16 are about all you can get nowadays.
Re: Spark Plugs
When I took custody of my 20/4 in 2007 it came fitted with a set of NGK AB6. In the box of spares that came with the car was a full box of AB6's. It seemed to run OK initially but after a few miles I was plagued with an intermittent misfire and poor running at idle. I could not find anything wrong but in desperation tried a new set of AB6's. This cured the misfire but about 1000miles later the misfire returned. Another new set of AB6's and the story repeats.
I then fitted a set of Champion D16. 5000miles later the car is running well but the plugs are a bit sooty. D16's are the normally recommended plug and NGK are supposed to be equivalent but my car does not run well on the NGK's. So next I tried Champion D21. I have now run 25000miles on the D21's, the car runs well on these and the plugs stay clean.
I conclude that although D16 is the normal recommendation, the ethanol content of modern fuel results in a lower combustion temperature, therefore needing a "hotter" plug. Of course others may disagree!
PS
I had a conversation with a friend with a Seven who also had problems with sooty plugs and persuaded him to try D21. It cured his sooty plug problem.
Best Regards
Pickles
Re: Spark Plugs
Post by Pickles »
Shortstroke wrote: Wed Sep 07, 2022 11:59 am NGK AB6 or champion D16 are about all you can get nowadays.
Thank you for the information. Much appreciated
Pickles
Re: Spark Plugs
Post by Pickles »
Martin27 wrote: Wed Sep 07, 2022 6:39 pm When I took custody of my 20/4 in 2007 it came fitted with a set of NGK AB6. In the box of spares that came with the car was a full box of AB6's. It seemed to run OK initially but after a few miles I was plagued with an intermittent misfire and poor running at idle. I could not find anything wrong but in desperation tried a new set of AB6's. This cured the misfire but about 1000miles later the misfire returned. Another new set of AB6's and the story repeats.
PS
Best Regards
Thank you Martin, information is very useful. I think I'll go with the Champion D21's.
