No Spark - help!
Re: No Spark - help!
It is always a good idea to check the earth connection from the battery to the chassis first. I have been caught out several times. An underrated positive lead is also a common problem if it has been replaced.
Have you tried putting a couple of gallons of fresh petrol in the tank and going for a run? You may be supprised at the difference.Modern fuel looses its volatility.
