Flywheel "cone nut" bush
This is the area for discussions regarding spares for your Austins
Pickles
Post by Pickles »
The bushes for the flywheel cone nuts have seen better days. I would like to replace them but it seems they are unavailable. I was thinking of using shim material as a replacement. Can anyone give me guidance on whether this is a good idea or should I try to machine new bushes?
Pottery50
Re: Flywheel "cone nut" bush
Post by Pottery50 »
Used brass shim to make a couple of replacements years ago with no problems.
Good luck.
Pickles
Post by Pickles »
Thanks you, will try that.
