Rear Hub Puller
Rear Hub Puller
I have recently purchased a 1928 12/4 Heavy Clifton and need to change the leaking N/S/R hub oil seal, can anyone recommend an off the shelf hub puller please!
Re: Rear Hub Puller
I found one that fitted on 4 of the wheel studs on Ebay.
Re: Rear Hub Puller
If you have to change the oil seal felt go for Derbyshire Austins modern lip seal conversion.
Re: Rear Hub Puller
Re: Rear Hub Puller
I am hoping to include a piece describing how to construct a hub puller in the winter 2020 edition of the VAR magazine. I have seen this tool in action and it works very well, although it isn't an off the shelf item. I don't want to give too much away at this stage but, if you are interested and can't wait until December, send me an email and I'll give you a sneak preview of the article.
Bob Kendall.
Bob Kendall.
